MasterBlaster
Administrator Emeritus
And you can do it with just one wedge.
And you can do it with just one wedge.![]()
I don't know on the wedges .I just always thumped in steel spiltting wedges in with an 8 pound hammer.
I rarely "drive" a wedge when bucking, if i use one i just push it in as a place holder, that way i'm not creating a new bind where theres still wood holding. Makes sense in my mind![]()
Several things you will eventually do .Rock a chain ,put a chain on backwards and hang up a saw . If you get real good at it you might even hang two saws in the same log .![]()
If you take off the powerhead on a pinched saw, you usually can take out the bar. Its usually just the chain that is pinched. It always kills me seeing someone trying to cut a saw lose with its powerhead still on and in such a way that when its released it will fall.
Yes to wedges I would say.
When I am bucking large wood I always have some within reach.
To cut I usually will start on top and cut about 1/3 to 1/2 deep, then draw the bar out at full speed just before the tip exits the cut, I will angle the bar downward and plunge all the way thru leaving a strip of holding wood in the center, then cut all the way to the bottom. Once thru the bottom, bring the bar back up and cut thru the holding strap left in the center.
It sounds like a lot of work and maybe unnecessary, but it works really well. With some practice you'll hardly ever get the bar stuck. I use the technique almost anytime I buck logs larger than 30".
