Make your facecut bigger, that way you get out of the sapwood and more into heartwood, which is more brittle on oak and therefore tears easier.
Make it a habit to bore any tree, that has lean to it, as well as any tree you fall on windy days.
When you have a lot of practise, you can get away with just cutting from the back on a lot of questionable trees. The trick is to know which ones will blow up, and that knowledge only comes with falling a lot of headleaners.
It doesn't take any longer to bore a tree, so get in the habit of doing so. That way you'll not be so likely to die young or if you are a professional faller, have some forester rip you a new asshole for splitting a 1000$ veneer log.
