Stig's recent reply got me motivated as I was close to finishing my three bowl project.
Here are the pic's. Each bowl has it's own story so I'll try not to drag this out. I downloaded the pic's first so I hope I get the order right for each bowl. At times I thought I was making small pots instead of bowls
Bowl #1 is made from Apple with some spaulting in it or maybe a better way to describe it some rotting. Apple is pretty wood but like Stig mentioned it can be a pain to turn. It can split,pieces break off if your too rough with the tools this piece was no exception so I quit while I was ahead but it still didn't turn out like I wanted it to. It would have turned out better if I sanded more like I did the other two. Apple will split within hours after you turn it. You have to get on it quick with sealers to keep it from checking too bad. this piece was finished with two coats of Tung oil with a top coat of Shellac to give it some shine.
Bowl #2 is some spaulted Maple. I have always liked the look of spaulted Maple but it too is very difficult to work with. I wanted to try U-Tubes Captain Eddie's "Shine Juice" as a finish but screwed up mixing it the first time . I dumped brush cleaner in the mix instead of mineral spirits, that bowl looked awful which meant resanding the whole bowl along with using some sanding sealer as I resanded it. I don't know if made a big difference or not. I got the "Shine Juice" right the second time and used Stig's method to apply it on the lathe. I liked the way this bowl turned out. It has the look I was looking for along with a nice shine and a really nice smooth feel when you touch it. The other two bowls have a some what rough feel because I didn't apply the finish on the lathe even though I sanded them on the lathe.
Bowl # 3 is Cherry, the goal on this one was to use the chuck and finish it with no tell tale signs it was ever on a lathe. I did accomplish that goal but it was a trial and error process. The bowl was suppose to be bigger and was going good but I didn't get rid of all the pith and splits were showing up and during the hollowing process I got a catch with the bowl gouge and really made a couple of deep gouge marks in it. I had to reduce the overall size of the bowl to get rid of these marks. The darn thing still has some small checks in it even after putting the finish on it. The finish is two coats of that shine juice only applied with a brush on the first coat and a shop towel for the second coat. I am not impressed at all with the way it came out . If I had applied it on the lathe like the maple bowl it might have turned out different.
I have just about about given up on Cherry wood for the lathe. I like the color but it splits worse than apple, the grain isn't all that great either. I have made boards out of Cherry logs that look really good and have stayed stable during the drying process with very few checks and minimal warping. I don't know I guess it all depends on individual pieces of wood.
I could go on and on with this bowl making experience but will end it here. These bowls were a first attempt and a good learning experience for doing future bowls.
In case anyone wants to know what " Shine Juice " is it is nothing more than 1/3 Shellac 1/3 boiled linseed oil 1/3 denatured alcohol. I used mineral spirits instead of alcohol. I was going to be daring like Jay and add some urathane to it but didn't.
