What is a Good Way to Attach a Pull Line to a Trailer Hitch on a Pickup Truck?
  • Replies Replies 120
  • Views Views 22K
Good showing of how to do it...thanks. I downloaded your picts and rotated them to normal on my computer. Then I posted them...guess what...they came out sideways for me too. The sideways picts thing is goofy.
I figured editing them here would make them right.....nope.
Beware grease from the tow-ball (just makes a mess), and you could just hang a POW over the ball if in any doubt.
I can't picture how the rope stays aligned, without rubbing on the hitch slug somewhere with an edge.
SeriousTreesAZ, per Sean's concern, from your excellent pictures it appears the rope coming off the hitch (working/running end?) isn't contacting an edge of the trailer hitch.
Evidently you are satisfied that none of the other rope wraps will be contacting any hard edges either during the heavy pulling? Thanks.
Do you mean a half hitch on the ball with the running end in addition to the wraps around the hitch?
...so that the full load of the pull would be born by the half hitch?
Exactly, those edges it's wrapped around are rounded and it's wrapped on itself several times so the tensioned end of the rope does not make contact with any rough/sharp edges.
Although you are supposed to grease all trailer couplings, most smaller (under 20k) trailers and couplings aren't greased because it just gets on everything, and it's not enough weight to matter for most people.
Really. Interesting.
I grew up seeing tennis balls over tow-balls. Was told you're supposed to grease them.
You can see wear on the ball much more easily than you can see it up in the coupler. Never heard of a coupler breaking.
Fair enough.
You are supposed to grease them, it's just that the amount of wear on them is almost non existent on smaller trailers. The semis are greased so heavily that walking by them will get some on you, but for your bumper pull trailer, grease is almost pointless for occasional towing (which is what bumper pull trailers are designed for).
Yeah I've seen the Porty on the hitch configured a few different ways (i.e. either hung on the hitch like the picture, or girth hitched to the body of the hitch) but I only use that if I'm pulling more than 9000lbs+ worth of tree or so which is rare... Works great.
