Been a little short-handed lately. My one employee, 32, is out indefinitely with a pre-existing GI issue. Ulcer/ Reflux thingy that Thanksgiving over-indulgence has brought to a head. Monday he came in to work, and told me he might be out for up to two months. He's been down this road before.
My other guy, 37, pretty solid, ready to learn, coming in with some skills, Desert Storm Marine, good with a wrench, has been working out well. He's not got as young of a back, but likes doing things the easy, efficient way, mostly, and everyone goes home with all ten fingers.
He and I did a quick box build. The F450 has been doing ok, with the little driving its gotten. Its had a tune-up. Needs some other TLC, like rubber, and the heater fan is noisy. It was $2850, 220k, gas 460, with a new clutch. Might be a shorter term truck. Much needed upgrade from my 1/2 ton rwd. I no longer am at the mercy of only one medium-duty truck for hauling and towing. Should be a big improvement until I get a second dump truck. Upgrading a trailer soon, too.
My SuperJr stump grinder is giving me a headache after changing the fuel filter (and I thought I was doing it a favor). Recently replaced the fuel pump and ground a big stump (it climbed over the stump and tipped over, breaking the old fuel pump, that was starting to go, anyhow). I will have to check that the pump is still connected properly (mental problem solving while typing). Older, but lower hour, Onan 25 HP with a diaphram-type fuel pump, actuated by the pressure from some part of the engine.
I filled the gas tank to try to make it as easy as possible to fill the system, but I can't get it 'primed' (I think one would call it). Seems like there a long stretch of air in the line. I might try detach the fuel line right before the pump and pressurize the gas tank with a clean funnel, some duct tape (gray magic) and lung power, pushing fuel all the way through (again, mental problem solving while typing...wish I had thought of that before).
Around $100 in new materials. Under 5' wide, 6' tall, 8' deep. Took us the morning and little more to build. It was cold this morning, snow, and the bed needed to be emptied of yesterday's chips with improv'ed walls for a day (short-handed, and sick kid this week). Had time to get over to the job, and put it to use on yesterday's pruning before dark.
Basic light frame walls, 2x4's across the top, leaving an air gap along the sides for venting, with a 6" plywood strip running front to back on the ceiling to greatly reduce debris blowing out. I'll probably get some fiberglass window screen in place of them.
Simple tail gate for the moment. I'd like to add dutch barn door that lock for short-trips-into-the-grocery-store/ restaurant level of security.
