"So when you cut down a tree, do you start at the top and work you way down?
Usually
Before
After popping the top, first main cut
Catching a log
After
Moved for firewood pickers and chip haulers from the residents of this 55+ park
Working top down, none of the limbs broke, or not much, when the top and 2 logs with limb sections rolled down the crown. The branches tangled a lot, so it was using the tree to rig itself, with a 5/8" line on the butt through Rig and Rings, to keep the falling section from rolling off the remaining tree, and stop it before it potentially punched a hole in the asphalt if the end hit.
I meant to cut the ~5' face, then build the crash pad, but forgot and built the pad (plywood, then lots of brush, the topping cut log on top crosswise) before the face. I had to re-cut it a little to hit the pad. No damage to the asphalt or concrete sidewalk.
I used some side and back limbs to build the pad. The trunk went in 4 pieces. About a 30' x 12" top, then two 10' logs, and a butt log flop. I crippled the butt log limbs by undercutting them on the way down until my bar was almost pinched. They broke away without leaving a big protruding stub that could have pierce the asphalt.
Used the mini to move all the brush to the chipper in the shade, rather than backing up to the full sun asphalt. The butt logs had to be cut to about 4' sections and bulldozed across the parking lot.
