I bought a Hooeyman(compact, telescopic, short blade, heavy...on sale), then later, used from a guy leaving town a lightweight Silky Zubat and a longer Stihl pole saw after rarely using pole saws beyond chainsaws.
I've used a fiberglass pole with hook for deadwood.
Alder tops are the best use I've found for them where nothing else is possible.
I can cut them partially, then pull and direct the branches somewhat into the drop zone.
BMG rake for the win. It is essential for us at this time of the year and we use it on every single job to clear the snow. Unfortunately, it also means it is mat season. Welcome to the to the time of the year where the work takes twice as long to do.
I’ve been thinking about making another BMG rake but out of an old mini track instead of the brush for snow removal.
That sounds really interesting. I would curious to see what that looks like and how it works.
I have a BMG rake that the bristles all rusted off so I want to use that old carrier to hold the track section. Easy on easy off save the bristles for turf clean up not snow pushing. I built a plow for the mini but that’s too big for daily use on a job. And the rake carrier is fairly small and doesn’t take up much space in the trailer.
Took the micro chipper to an HOA greenbelt job. Rolled it from pile to pile downhill to where we reloaded. No drag.
In dry weather, I could have driven the big chipper in there. It was only 1/2 to 3/4 of a yard of chipped material.
Then to a tight roadside pull off in another green belt at the crest of a steep slope and a less steep slope and a curve. It was not a well suited for the big chipper and only a half a yard, maybe a bit more, of chipped material. The rest was firewood.
Nothing special.
I would've guessed your boom was shorter than 124', but since it isn't, that's a good amount of reach
Btw, I guess 'tree guys' don't need a crane license to operate a crane in OH? In CT, it was like that for ages until the last year or two now the law changed and every op needs to be licensed which involves passing a difficult test full of alot of Q's re rules and regulations, behind mere operating ability
Got a call last night from an acquaintance from the climbing gym about a tipped alder.
You betcha.
Changed my plan of completing an HOA project's couple remaining line items that were non hazardous for this job.
He will clean up. He detached the handful of rigged pieces and tightened the rope- puller a few times.
Told him to expect 5 hours, no more than 8, that I hoped it would be 3, and it was 3.75 till boxes opened to closed.
Climbed an adjacent alder to the top and installed a retrievable trunk choke.
Then added a guy line before spurring up the lovely alder with mushrooms on old trunks butted against this one, which showed no tension side root.
20251205_130003.jpg 20251205_130010.jpg 20251205_133156.jpg 20251205_133202.jpg
Monster marine crane in the Port of Olympia.
That was a subs crane. And both him and I are licensed crane operators. This was his Altec45/127
Wow, nice crane. Do you like the 45t alot more than your crane?
Why were they removing that biggun
They are getting rid of all the Siberian elms. They were planted years ago as a fast growing stopgap. They are kind of a rottonwood…get hollow and rotten and drop limbs. Seems to be largely from pruning too large of limbs off.
It was a fun job. A bunch of them semi-tricky, down and buck the butt log off only. I hope to do more on Christmas break and maybe bring some logs or slabs home. It’s kind soft but quite pretty.
