Arborkeith
Holmentree, have you run a machine besides your 252 that was belt driven? I've replaced jack shaft bearings on my machines at every 800 hours. Around 500$ for the bearings, 3 1/2 hours to change. I change the main drive belt once a year at 85$ a pop. Never had an adjustment issue. The reason I ask if yours was a rental is that if the alignment gets off in a belt drive system, it spells trouble. It'll throw off the belt, prematurely stretch the belt and cost a lot of money, sometimes rental yard "mechanics" don't know how to put them back together so that you can avoid these problems. And my Carlton 7015 Trx was bought in October of 2005, has a little over 1600 hours on it. So I consider it a cheap easy system. It works for me. My Carlton 7500 is a 2002 model that I bought from a friend. It has just under 900 hours on it and has had one set of jack shaft bearings on at 800 hours, and a belt every two years(it's a wider heavier duty belt). Overall I'm very satisfied .
