Squirrelmax climbers?
  • Replies Replies 52
  • Views Views 9K
flushcut
Delavan, WI
Did anybody else see these in the back of the march issue of TCI magazine? They look very similar to a pair the G.F.B.s book.
  • #8
I just reread the info and it is said that they are being sold through American Arborist and for more info contact BGO Consulting and Development,LLC #610-241-7469. Hope it helps.
I saw them. They have a swiveling attachment between the shank and the pad. The articulation is supposed to make them more comfortable.
I tried his prototype in Baltimore TCI. I was sold on them with the 1st try.
Really happy for him.
My kliens must be going on twenty years now, and these will most definetly get me thru another twenty.
Full floating rigid pads are far more comfy than fixed rigid pads. Back in the early 80's I used a gimbal between the frame and the pad for the same effect. It works great. Really evens the pressure from the hard spots in a rigid pad. Easy fix really. About time someone picked up on it.
The pivot point needs to be at the ankle joint. The top pivot will improve shin comfort, but an ankle pivot would allow articulation of the spike by the foot and maintain even pressure at the arch support.
Dave
I believe that would tend to bear pretty hard on the ankles myself, Dave.
I built a set of mini spurs one time with the thought to save on weight and bulk on the back country climbs. Man that proved to be a big waste of my R@D dollars and time. They failed miserably.
Of all the production climber pads out there I have to say the Geckos are the best of the lot. But spurs wear different on us all. The bottom line is what is comfortable for you. And when standing in the hooks for 6-7 hours comfort means a lot.
Where those the klines, Butch?
About 1980 Klines first rigid pad was set on the frame at a hard 90 angle. Which made only the top of the pad come in contact with the shin. A terrible design, but the pad itself was cush. A few years later Kline modified the pad by tilting it forward about 15 degrees and left slop in its fit with the top of the frame. That simple fix practically evened all the back pressure exerted on the shin. and being rigid it eliminated climber kick back. It was one of the first innovations towards making spurs ergonomic and half ass comfortable to wear.
Just a simple tweak.
