N
NeTree
I switched to the night vision app I downloaded. I see you clearly.
You can do the same thing with the Goods. There is just enough room to place the bollard below the winch and add another ratchet strap and you can then rig two lines, you'd need to set up another fairlead for two ropes.
I have eexperimented with it the other way as well with the bollard above the winch with a wrap around the bollard and using the winch to take up slaack or pull before snapping off a piece and then letting it run. Takes alot of the shock load away from the winch. i can't be the only numskull to try this. I use a limb to prop up the winch or bollard to keep it from falling out, I should get to the welder to do up a permanent extension for this tandem feature..
The Goods is great!
