murphy4trees
center of round; but also center is most likely to be stiffer less flexible fibers
1/3 a good for hinge because not into stiffer center model;.
I believe this is a common misocnception in the industry. When there is solid heartwood and maximum control is needed from the hinge I ALWAYS use the widest hinge possible... The difference between hinge strength in heartwood and sapwood is influenced by species and moisture.. HOWEVER I can show you a LOT of photos where the heartwood fibers off thehinge had the most control and where the largest whiskers...
The idea that sapwood held better was most likely a misinterpretation of fiber pull down the side of the tree, ripping out long strands of bark.. One might look at that and say.. these outer fibers had the most strength becasue they held the longest and caused the bark to rip and sometimes pull the tree of the lay... The only reason they ripped down the sides and the center fibers didn;t is becasue the center fibers had no where to go.
