I have a 97' F450 4x4, gasser, 5speed that ive been slowly cleaning up.
This is what it looked like when I bought it...used hard!
Cleaned up a bit at home pic
When work is slow I try to get something done on it (if its not a 100deg out lol) so I power washed all underneath, running gear, frame and what ever else I wanted black enamle on. There was very little rust being a CA truck so prep was easy.
heres a pic of some of the frame/running gear that I sprayed with spray gun.
Sprayed the bumper and grill, fixed bezel light...ash tray was broke, plastic kick panel was gone, E-brake pad and lots of other little pain in the butt stuff that needed some TLC... so "pick-in-pull" here i come...found everything I needed there, nice!
Clutch didnt feel right and had vibration through every gear, something just was not good, so took in for clutch and they said a 1/4 of clutch material was missing...well thats the vibration being out of balance feel.
Next on list was tires and paint rims...a couple back tires had some deep slices on L-Right rears...so had them dismounted and sanded and sprayed rims gloss white, about 3 coats...6 rims was a lot of work but turned out good.
Did the front and rear brakes while rims were off and lubed zirks on front axle and blead brakes.
