Climbhigh
- Joined
- Apr 8, 2015
- Messages
- 259
- Thread Starter Thread Starter
- #26
Had a little time this morning so gave the goop a try; slathered the full length of pitchy rope with GOOP, let it set for 2 hours, drew a warm bath , threw my rope in there, worked it over with a brush real well, then into the top load washer with some Woolite.The Goop took care of the pitch as advertised ( Thanks Bernham ). The rope was still pretty dingy looking cosmetically, I think mainly because it is a white rope and rubbing on the hitch hiker aluminum body turned it black. So at this point I thought, well there's no more dirt on the rope so shouldn't hurt to give it a little pressure wash. So I put the rope in a 18 gal. tub and put a wide angle tip on my pressure washer. I pressure washed and flipped the rope around in the tub to get all the angles. This is the part that amazed me,is how much soap and Goop was still in the rope after spending 30 min washing and rinsing it off in warm water and also running it through the washing machine. So I spent about 20 min. pressure washing flipping the rope around and dumping out the tub of soapy water when it got about half full, I did this about 15 times before I was satisfied that I got most of the soap out of the rope. End result after all this; sparkling clean white rope. This will be my new rope cleaning method (Sorry Butch ).
. Hang to dry in a moderate temperature, out of direct sun location.
