flushcut
For me bars are considered a consumable tool use it, burn it up, and replace tho thru out it's life I do reclose the rails, file off burs, and replace nose sprockets as needed. IMO wore out is wore out and gets tossed.
No. If all is correct it chain will ride on the two sprockets with enough tension to stay straight between the rails.Not true, except when saw is in upright position. Gravity is the culprit, combined with grit/sand/etc. When the saw is in felling position, the chain is "lying" horizontally, putting pressure, therefore wear, on the bottom edge. Which edge is bottom is relative to how the saw is being held at the time.
Willard, I've had bars that looked more worn than that after only a couple of months. Not sure how you keep the paint on there.
Tiestraps sit on the rail at all times.
When chain is worn in rivet and drive link hole it will bend sideway's at load is put on the tooth. It will be same if a rim is worn out.
I not only understand fysic's, I also understand mechanic's.. I also understand weights that is spun on two points very fast have other problems than gravity.Magnus, do you understand physics? Gravity? There is no way you're going to get enough tension on that chain that it won't ride on the downhill side when the saw is in felling position. If you do, the chain AIN'T going to turn. I know for a fact that the chain wears the downhill side, widening the groove. I have seen worn bars/chains with the chain visibly canted.
Thinking that might apply to our poster here...we might just need to hammer hard.
If all is in order, the theory says so, but it will more likely just jam sooner if there's something wrong.I've always thought maybe an extra wide bar like some of the canon bars might cut straighter
Treebilly, to see if the groove is too much worn (and /or the chain for that matter), put a rule vertically against the bar (upright, normal position), going by one cutter's edge on both up and down sides.It's an old bar. What should I look for in " play" if I grab the chain and rotate it sideways.
Yeah, I hooked them up with a GREAT source that offers prices hard to beat, because of their perceived position. Then to hear them ask about carbon fiber bars, after I get a nasty phone call from the person I suggested. I'm out!
As for the other party, I've got a lot bigger, and more meaningful things in my life that I need to deal with, and I'm sure they cannot comprehend that thought, so again, I'm out!
I think we gone over this before.
Over time a wire edge will form on the outside edge of the rails from normal wear. If not regularly filed off lightly with a flat file at a angle the wire edge will get big enough to break little chunks of steel out.
File with long strokes the full length of the bar . Don't take off more then you have to
