ms 460 bearing question
  • Replies Replies 28
  • Views Views 6K
Auto parts store usually carries it for wheel bearings on disc brake rotors. Basically, high temp axle grease.
Thats what I use on sprocket bearings. I just use finger to wipe outside of bearing and wipe a little on crankshaft area. Never a problem and never excess anywhere.
I use the NAPA high temp which is the Valvoline high temp.
I just use my 100% synthetic Klotz 2 stroke oil for that bearing and rings on rebuilds. Used my 80/20 and Dino oil before that. All worked the same.
Ha I just drown the things with 30WT sae and if it doesn't smoke for five minutes after the first start up I worry I didn't get enough oil on it .
