Material Mover
  • Thread starter Thread starter TREECYCLE
  • Replies Replies 57
  • Views Views 6K
Decks, shrubs, any over head obstacles
Bingo. Also my storage facility is only a 7' door. ;)
Also on the payload numbers. Stock is 2976 and I put foam in each tire for a total of about 200 lbs in the rear. I am sure that it will lift 3200 and think that it will lift a bit more than that with the right conditions. That's a big log. It always surprises me when I think it may not lift something.
Anyway the ROP is a pain in the azz. Seat belts are for people to who can't get clear of the machine. Anyway what would happen if there was a log where you were rolling over? Strapped to the seat? How about just a simple stick plunging into your lung? Here is another scenario. How about if you were rolling down a steep dirt grade with a deuce and a half with a drop off on one side and a wall on the other. Do you strap yourself into the seat or keep your hand on the door handle?
I don't know what is best always. I like to think that everyone is entitled to their opinion. I am still learning a thing or two about my own mortality. I am not exactly old and wise but I've seen a thing or two.
I would rather a ROPS than a handful of whimsical maybes. But thats just me, and I dont have that kind of machinery, I just drive other peoples gear once in a while. :) Each to their own.
I hear ya. I need to get it back on there. It's only 4 bolts. Don't get me wrong, I was just saying. Sometimes I think that all the safety stuff and signs everywhere are just a way to "make" me feel safe. Over thinking things is usually where I get myself in trouble.
I still do not like the safety chain even though it is proven to reduce kickback.
its all good, I dont like over regulation either but some of the safety gear is easy enough to use without hindrance. Have at her! :)
So instead of ROPS you now have ROD. Roll Over Death.
I never came even remotely close to rolling over my Gehl. Very simple not to roll over machinery. Don't make fast turns and don't drive sideways on slopes.
The first job I used the Gehl on had a tree branch 6 ft. high over the pathway. With the ROPS we could not pass under it. I was not about to drag brush 120 ft. when I had the Gehl there with the BMG. The ROPS came off then and never went back on.
Lumberjack drove my Gehl for more than 6 hours moving logs when he was in Hawaii. Carl, did you feel unsafe or in danger of rolling over?
Not at all, but we were working on (mainly) flat ground. If I had it I'd probably leave it on, taking it off if the job required as I've rolled my mini plenty of times.
Dang Carl, if I knew you were such a dangerous driver I would never have let you even sit in my Gehl.:lol:
Like I said earlier, I never ever came even remotely close to rolling over either my Gehl or the Prowler. I do not operate it in dicey conditions.
Ha if you ain't living on the edge, you're taking up too much room!
Here's yesterday's interesting occurance:
Kept the rubber side down :)
How the heck did the mini end up centered on one ramp like that?
I don't drive my loaders carrying a load up ramps.
I was pushing that chunk up the ramps and apparently got a bit carried away.
That's how I load nearly everything, it doesn't lift high enough to go over the side.
I let him ride mine too :O :O
He didn't roll it, but I have rolled several swingers . . . . hit a bridge . . . started a trk on fire . . . . crushed a fence etc etc etc ,
My emps called me Captain crash
I'll have to keep this in mind if Carl ever makes it up to Kansas for a visit. :P
Carl, A set of forks will allow you to get a grip on those big bones a bit better. But I bet you knew that already. Here is a tree transplant job we did with our loaders. Put on your dancin shoes....
<object width="445" height="364"><param name="movie" value="http://www.youtube.com/v/fT9KO7AIjA8&hl=en&fs=1&rel=0&color1=0x234900&color2=0x4e9e00&border=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/fT9KO7AIjA8&hl=en&fs=1&rel=0&color1=0x234900&color2=0x4e9e00&border=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="445" height="364"></embed></object>
Beautiful job! What kind of time and guarentee did you put on that?
zero guarantee for 0 months. The homeowner knew there was a chance that it wouldnt make it. It was either try to move it or cut it down to make room for a swimming pool. We dont do this kind of work often but I think it has a great chance of survival. The video was posted to show an example of a material mover.
