We get into some situations where given the reach, it's dicey whether the crane is beyond the maximum limit of its ability to pick up the weight of the tree.  Using that cut, the butt can slide off and immediately hit the ground, and then the log can get slightly lifted to see how the crane responds. The weight is OK, the log gets lifted, if not, it gets bounced close enough in to where it can get picked up.  Boring out the middle allows for better alignment when making the back cut through to the center of the face.  No hinge, just a clean smooth break away and slide off is desired.  The log twisting can be a problem with this cut for that purpose, pinching the bar. Care for an even back cut, so one corner doesn't break faster than the other, and a wedge can help
