MasterBlaster
Administrator Emeritus
On a tree that small you don't need wedges. I would leave them in my toolbox and instead just push.
On a tree that small I would leave my wedges in my toolbox and instead just push.
the point at which either cut passes the hinge
I assume you climbed by yourself to finish that job. The better way would have been to have a ground man there pulling the pieces over with a rope.
...(post 27, or click link <<<)...
here gary i found you a "proper dutchman:
Again good job done Gary. Finish that sucker off and get paid![]()
Gary's notch is a conventional notch. A Dutchman is basically the same thing only in reverse with the angle cut coming up from the bottom to meet the floor cut.
sounds like a humbolt?
I should have checked that out before typing. The correct name for all the different notches and cuts gets away from me because I just don't have that much use for them in the type of treework we do. A regular notch and sometimes an open face is the norm 98% of the time. The other 2% will call for a different type notch which is nice to know and how to cut them is even better.
