Instagram
  • Replies Replies 2K
  • Views Views 147K
Spur up, set the line, then do your work? Not sure how you could see what you're attached to from the ground. Hopefully, cutting a palm is something I never have to consider.
Therein lies the issue.
There are folks that shoot a line over and manage to pull up a climb line.
I never did. Spur and flipline up, tie in at the top once I could see what was going on.
Cambium saver false crotch under the crown and lanyard up in around several fronds.
The angles between the fronds is very narrow, and some frond bases are covered with thorns.
Getting a line through then retrieving it, well, props to those that can and do!
Swinging from one to another could be fun.
Coconuts the best, at least you got a snack out of them at the end.
