pantheraba
More biners!!!
How bad could a 4 foot slide be??
(I saw (and heard the "pop") a girl break her ankle from a 6 inch fall...not tree climbing but broke nonetheless)
Thanks All!
Sean -- Thanks for ALL the great detailed tips and info. I have heard about boring in vertical with the tip of the bar, but was never 100% confident that it was a safe technique (not compromising the trunk somehow). It is good to know that you use this technique.
Butch -- Thanks. Good idea. I still haven't gotten a saddle, but I'm supposing a full body harness would come with the aerial lift rental.
Sam -- I appreciate your knowledgeable perspective.
Merle -- Thanks for the good info. Yeah, I am just trying to digest everything and make it my own, so to speak. Was it you, Merle, or somebody else I was reading here about a case where the boss insisted he do some positioning in a tree, etc. the bosses way instead of the way he was comfortable with and it almost caused him a serious accident.
Thanks.
Most don't, but it IS a safe practice.
On a side note , when I look at bidding work like that 100% of the time they have had several bids in the past and didn't go for one or someone said they'd do it and didn't. (If I'm low bid I have failed IMO)
I understand that doing that is handy sometimes, but he has several dead ones to remove from my understanding, and standard operating procedure to remove dead trees can't be park pickup in yard, grab pole saw, and hack limbs off. Can it be done, yes. But thinking that is how it's done isn't gonna do him any favors, and if he just rented a lift he would knock several jobs out in a weekend, and make more money faster. I rent a lift all the time if I have a bigger job, several of them to do, or dead crap ones like those he pictured. You lose some money to the rental fee yes, but he will do several jobs in the same time frame, make more per hour, and probably pick up other jobs because he will look like he's done it before.
Or just climb them. You said you wanted to climb trees, right? Those all look small enough. Climb up 10-12 feet, whack off the limbs without cutting yourself or falling out of the tree, then come down and drop the stems. EZPZ
