I'm wondering if there is any consensus (probably wishful thinking) on what works best as a tether for tending the HH.
I made a wire tether from a high tensile strength bicycle wheel spoke which got bent up on my last climb when I wasn't using it. I was about to order a tether from TreeStuff last night when I decided I should at least see if one of my sewing machines could do the job.
Surprisingly, it worked well enough at stitching 6mm accessory cord for a tending tether. After stitching the eyes, I dipped it in MaxiJacket to provide some stiffness. It may need dipped another time or two and it may need to be longer. Here's some photos. The first two are before dipping.
What are the rest of you using? Photos would be great. Thanks
