SouthSoundTree
If you have the tools, AND the trees are strong enough to go big...
No crane access? Some or all negative blocking?
Will you rent a machine for moving all that stuff?
Believe you me, Nick, that post earlier is not knocking. Removals are so much more work than fine pruning for the money. Pruning rarely takes as much of a slot in the schedule, though. Seems like your market.
I've only got 9/16" DB for my big rope, and we used 5/8" DB with a porty to negative block 8-10' logs off a 30"-ish Doug-fir without issue. I usually use 1/2" three-strand, with its built in stretch. Usually no room to go bigger, or by the time I'm on trunk wood, I'm top-rigging off another tree, or more likely, bombing onto a pad or grass...or use a crane.
