tophopper
The resident asshole
You dont have to buy new Justin. We bought our first clam used in the neighborhood of 50-60k.(A 98 Peterbuilt, 10 speed, tandem axle with a Serco 8000 loader) The point Im trying to make is about the position of the loader on the truck. If you want a true "grab truck", thats a rear mount, they give you the best reach, manueverability, leverage, positioning, and speed. The work area is on both sides and the rear of the truck. A cab mount and you can only load from the side (or over the cab ), thats fine for picking up debris from the curb and such, but if you need to get into any tight areas with it you'll find yourself limited in your set up because you cant load from the back of the truck. One could argue that it really wouldnt be an issue if you have forwarding equipment to move the material closer to the truck, but its so much faster, to hammer down a tree into a postage stamp yard and just make a shit pile mess, back in the loader truck, grab it and go. No forwarding needed. Many times you cannot do that with a cab mount because of its limited working area.
And if your looking to run one or several crews a rear mount will serve you better too with faster debris pick ups between crews. No trailer , no dickin around, just grabbin brush and logs left and right, running all over town.
