for the same reason you tie in twice...
I think a more accurate analogy would be climbing lines, as in, do you use 2 every time you climb or just when the situation makes it prudent?
I'm guessing you don't have crane experience.
Once you spider leg you won't go back.
Time is money.....but safety is paramount
Both accidents here were for the same reason. Load began to flip.....then broke.....fell onto climber. Spider pegs or multiple attachments would have prevented
But hey, throw the dice......win or lose. Then your ego bitch slaps you.....
...I'm guessing you don't have crane experience...Once you spider leg you won't go back... Then your ego bitch slaps you.....
Because if you do it right you don't need it.
Wow! Talk about ego. Believe it or not but there are climbers, myself being one, that will use whatever is needed for the situation at hand, even on a crane job and yes I have indeed done 1 or 2.
Spider legs aren't a gimmick to make money, if you have seen the advantages with using them and make them up yourself. A person like MB with his experience, I wouldn't begin to try and convince to use something that he questions the merits of, but for the sake of discussion, I can say that I know a few different long at the game tree outfits that have gone from using a single choker method to using multiple attachments on a regular basis, after seeing how they work on broad trees.
A tree like the dead oak and wanting to take fairly large picks with limbs, simple half hitch each leg of a multiple attachment rig around a larger limb that you deem reasonably secure, then fasten off the remainder of the leg low around the trunk with no slack. With three legs you have six points of attachment going, acting both as a balancing act and backup if a limb should give, and also distributing the weight and mainly holding it down at the trunk. I would dare the pick to break free and fall, I just can't see it happening. You want to drive the pick through another tree, who knows, but a gentle lift off with little tilt or twist and settling to the ground by the crane, I'm not losing sleep. Even with some strange act from God, you aren't going to lose the thing. Safety precludes bravery...
and if you want to get a tree disassembled in a hurry with larger picks, often multiple legs will better allow that, imo.
I agree with your premise, Chris, to only use what is necessary. Our spider legs are three legged, and two often suffice, where one might as well. i can't agree with the statement that a spider leg arrangement can be made non essential all the time by a single attachment (you didn't say that), and if you want to get a tree disassembled in a hurry with larger picks, often multiple legs will better allow that, imo. A climber's time measured against taking larger picks, the equation can vary.
I agree with you David and Jomo. The tree and the job will dictate how's its going to be removed. "Spider legs" just for the sake of using them makes about as much sense as using 2 lowering lines for rigging a piece down when you know the size of the piece and approx. how much they weigh. and you know that one line will be fine. And, Yes, I know all about using DWT's and when they are necessary.
My crane operator (CO) and myself always take into account picks with the potential for slight tipping and shocking loading and he's a climber as well with over 40 years of crane experience. These guys were pioneers in New England doing tree work with cranes doing all Bartlett's crane business for years. My CO's father started the business in 1957 and they're still going strong. As a matter of fact, he's 79 and still will run the crane on small jobs. Never had an accident with a single choker pick in nearly 60 years.
I've been to many, many crane seminars over the years, but the crew that I contract climb for, REALLY opened my eyes to the proper ways of single choker use. Do we ever use more than one? Of course we do, but ONLY when necessary, not for the sake of making a pretty, balanced pick on every lift. These guys know their 1500 National crane inside and out and when they tell me to take a particular piece in a specific way, I listen. Its been a real eye opener for me climbing for them 3 days a week for the last few weeks.
Spider legs for the majority of lifts are WAY overrated and overkill, IMHO.
