BOOM!...well almost
  • Thread starter Thread starter No_Bivy
  • Replies Replies 90
  • Views Views 9K
No bivy, Black powder? I probably should not do this, maybe you already kniow about it. It's legal in most states until you mix it then it is certainly a gray area, can be detonated in a variety if ways, properly tamped on small enough material it would cut a tree.
Tannerite. Check it out, I use it to scare folks when I take them shooting.:evil:
:O
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/nkwzWw1ciqc&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/nkwzWw1ciqc&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
I know. wouldn't matter, black powder is waaay too slow.
Tannerite, its legal till you mix it. Then it gets interpretive.
Hell, now I'm thinking. If we can buy Tannerite legally cause its a binary agent, and the individual component is benign. Then we should be able to still buy Kinepac right? I know that works, we used the foil pouches on the Hotshots to cut trees.:evil:
Kinepac comes in a couple of different size tubes, a plastic jar, and a foil pouch. We used the foil pouches. Different size charges.
Tannerite has ammonium nitrate in it I'm guessing it goes off at around 10,000fps. Lots more bang than your black powder. Kinepac blows somewheres in the 20,000fps range if I remember correctly. Maybe a bit more, hell that was a long time ago.
I know for a fact you can buy the Tannerite.
  • #83
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/du5H5HnoElA&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/du5H5HnoElA&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
thtat looks like it would hurt, how did you remedy the last charge that didnt blow.
Were there different fps in the video?
  • #85
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/wjW7srAvtSY&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/wjW7srAvtSY&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
  • #86
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/79sJ1bMR6VQ&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/79sJ1bMR6VQ&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
That dude looked like Pat.
200 tons... a small shot? Holy sheepshit I wanna see a big one!
cement truck vs mythbusters :D
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/jkP28DFnHqU&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/jkP28DFnHqU&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
