treelooker
Gotta agree ! I'm all for thinking, and working, outside the box.IMO others have already learned, but you're simply repeating old mistakes.
But it makes sense to first look inside the box.
So every tree practice we do now is 100% correct and in ten years we won't be telling anyone that we used to believe X but now we believe Y? If no tries anything different how do we learn?
On the tags I would just write in the vertical spacing of your rods with the tag placed either at the highest or lowest (with that designation written in).
Dave
Only on thick-barked trees, and to the sapwood, not just the cambium.The BMP book on cabling and bracing that ISA sells says you are supposed to countersink the washer up against the cambium tissue.
Nothing is said about a second nut. Other options like locknuts and locking fluid are suggested. Peening is preferred. There is never any reason to back off the nut, as noted by Brian and others.Then you have to either peen the threads to keep the nut from backing off or else use two nuts.
Your options are to
1. Carefully read and consider the experience of the many arborists who wrote the BMP, or
2. Carelessly misquote, exaggerate, disregard and mock it.
your call.
