Best facecut for negative rigging?
  • Thread starter Thread starter Brock Mayo
  • Replies Replies 76
  • Views Views 11K
I thought it was something about all iPictures being turned to Landscape Format. no?
Hell if I know. I just don't think it's the forum doing it. Still waiting for my guy to get back to me.
I was reclining on my bed, with a smaller book behind my 8.5x11" printer paper.
Awkward writing position, sorta like lefties fight.
Being a lefty in a right-handed world of machines and design is something that seems challenging.
It ain't much of a thing. I'm pretty ambidextrous but I certainly fight left handed as well as write.
Anyone who's gone fisty cuffs against a lefty usually finds out just how awkward of a stance/position being left handed really is. ;)
Take for instance North American driving. Left hand on the steering wheel seems wiser(to me)than using your dominant hand to run a shifter. But I'm sure right handers manage just fine.
Fighting in a right foot forward position makes you easier to kick in the nuts for a person fighting in the " Normal" position.
Which goes both ways, of course.
I'm right handed and my handwriting has always been terribly messy.
The biggest advantage left handers have in fighting is that the majority of opponents they face are right handed so anticipation of a right handers movements and power position/attacks is the norm. Whereas for a right hander unless they've trained and can identify the difference in their opponent the left handed stance is foreign. So maybe not for you as a lifetime trained individual in hand to hand combat, but for most being left handed is an advantage.
https://www.newscientist.com/article/dn6773-left-handers-win-in-hand-to-hand-combat/
In writing English, left handers have a distinct disadvantage through the mechanics of using their opposite hand and so generally are known to have 'messier' writing/printing.
You are right about being a leftie is an advantadge.
Frigs most untrained righties completely up.
I knew there was a reason we got along Squish.
Sean I agree with the peeling but it is definitely species dependent and the rope man needs to be quick for the times it doesn’t work quite right.
Nice drawings Sean; good info all!
I tried to learn to write left-handed in third grade and the nun came over and cracked my knuckles and said, "Young man, I can't even read your chicken scratching when you use the right hand!"
another way of looking at it is what is the worst notch for taking tops, and negative rigging long pieces.
This would only be much of a concern before the wood gets thick, and you are chinking pieces..
The 45 degrees notch or traditional notch will tend to cause a lot more spring back... Especially on big tops.. The top starts to the lay, initially pushing the top of the remaining spar (at the cut) back away from the lay.. then just as all that weight of the top is laying forward at 45 degrees, the face closes and before the hinge fibers can rip, the top of the remaining spar (at the cut) gets pulled forward hard by all that weight leaning forward. And right as the hinge breaks some 10-15 degrees further into the lay, the top is now even more horizontal all that weight so far away from the cut, and the entire momentum of the top is pulling the remaining spar even harder. Then the hinge breaks and that spar will spring back so fringing hard you'll be hanging on for dear life, praying to God your hooks don't kick out and trying to keep some distance between your face and the wildly swinging stem... Not a pretty picture! so go narrow or go wide, but don't go 45
  • #47
That's interesting Murphy. I've heard an argument made, using the spar push back of a narrower face cut to counter the forward force of the block catching the wood. I don't think this guy goes 45 degrees, but argued that the open face is already pulling forward on the tree when the hinge breaks and then the wood catching on the block pulls even more...
Hinge thickness seems to be a key factor as well. Cutting tops is not a time I want a thick hinge.
with an open face the main force of the top is going down, rather than out when the notch closes and the hinge starts to break.... That seems to reduce the spring effect, however you have to be careful that there is nothing on the ground behind the tree, as the tips can hit close to the trunk and then the but kick back a good ways back from the tree (of you are bombing and not roping the top)...
A narrow notch causing the push back to be countered by the forward lean WHEN THE HINGE CLOSES makes sense... by the time the block catches the top though its a hard call to know where and what direction the spar will be moving... from studying video, it also seems that the top slamming back into the trunk has more of an effect on spar, that when the block catches the top...
I think the humboldt is a better cut to use when you are trying to engineer the angle of the top at separation when the hinge breaks, as the Humboldt seems to break directly after the face closes, which is about 10-15 degrees earlier than a traditional, which seems to take a good bit more movement to break the hinge.. That additional time that the hinge on a traditional also seems to add A LOT of pull on the stem.
So, to simplify things, a standard furry top off a stripped stem.
A Humbolt is better than a standard to reduce the ‘tooth smashing/rib breaking/ flying off the top scenario?
Is that a generally accepted thing?
(Assuming one chases the cut once it starts to do the right thing)
I'd love to see the math on that.
The force of a facecut closing doesn't alter because the face cut is upside down.
Just like we can't negate gravity by walking on our hands.
Pity, really, because that would just be so cool.
