I wouldn't know what to do with that......
I apologize for my delay, working long hours and attempting to catch up on sleep. I've tried embedding videos, my phone just says no lol
Yeah it basically uses the resistance of the metal itself to heat it to welding temperature rather quickly, and then pressure to make the weld. Lots of objects are welded that way, in fact i think it's the most common form of welding by volume of products. It's really a modernization of forge welding, which is the oldest technique of welding there is (Damascus steel for example). The heat treating is done to harden the steel and them add toughness back to it by tempering. Have you ever noticed logging chain really doesn't rust quickly? That's due to the carbon content, and the more carbon the stronger the steel, but it makes other processes like welding and machining harder to do. All the heat treating does is change the grain structure of the material to have the characteristics that are wanted. The wire is fully annealed to start, so the forming processes can happen cold. The weld adds stresses, which are relieved by heating. When quenched, the metal freezes in large grain structures, which freeze the carbon in place, making it very hard but brittle (files are used in this state). By heating slightly, the grain structure is allowed to get slightly smaller, and form small grains in between the larger grains, which allows them to move a bit before the bonds are torn (toughness). That's the simplified version for steel, different alloys get more complex
Basically the different alloys add a few molecules of another metal to act like a catalyst for freezing, which forms grain structures in a certain manner (same as carbon in regular steel), but they all do it differently.
