I currently run one.
Seems counterintuitive that a swivel will keep the rope grab horizontal...the weight of the tail of the lanyard will pull it into a vertical position, I think.It’s mostly to take the 90* twist” out of it to keep the rope grab horizontal. Some rope grabs solved this problem by turning the attachment eye 90* making it perpendicular to the device’s body. I have had the biner “bunch up” and load weird as well. The swivel will most likely solve this as well as allow me to pull from the most comfortable angle as I can align it with my strongest pulling form. I believe some minor twisting happens during climbing when minor rolling of the flip line occurs. This added to the way the biner connects the device to the saddle can worsen the situation.
The Prusik attachment will be investigated as well. I like that the handsaw or knife can cut it.
I don't understand why additional elements are needed at all. Brevity is the sister of talent!) Are you left-handed or is it more convenient for you to use the clip on the right for some reason?Is this the wrong way to add a swivel to my flip line due to the biner to biner action? I’ve always heard that was an erroneous practice but I don’t remember any reasons why.
You may very well be correct Burnham. I do tend to agree about swivels complicating matters which is why this swivel was sitting around unused. We’ll see how she does. The Prusik or twisted clevis may be the better answer.Seems counterintuitive that a swivel will keep the rope grab horizontal...the weight of the tail of the lanyard will pull it into a vertical position, I think.
