woodworkingboy
I used to see old timers using these pretty regular, fewer younger guys nowadays have picked up on the usefulness. They date back to old school methods. The short handled log pick can save a lot of stress on your back, makes for easier picking up while keeping yourself in a more upright position. Jab into the end grain and pull the log length from the ground up to yourself. One arm under the log and the tool poked into the bark at arm's length below makes for a helpful carry as well. Also good for hooking under branches to drag or lift up. No such beast here, but maybe useful for feeding a chipper?
The big hacking knife, Nata they call it, is real good for lopping off smaller branches, and with the thickness of the blade and weight of them and if kept sharp, often one good whack cleanly removes. An enjoyable tool to use with it's connection to the old ways, once you get in the habit of carrying on your belt and using, you really don't need a chainsaw and using gas to cut everything. It may seem obsolete in a sense, but if you get into using one, you may find it surprisingly purposeful. Probably not so useful for guys chipping everything, it occurs. I really like these, and it doesn't make for much added effort to carry them around on yourself if working the ground.
The Nata and picks are readily available here, but I prefer to make my own tools, or at least the handles. I like a little longer length on the picks than the store bought ones offer. The pick can fit into a little pouch on your belt in the back, short and light enough not to fall out. The stainless pipe pick handle I recently made for moving bigger logs
