S
sytherstrike
I read some threads on guys asking how to do it and is it hard. Well I figured I'd snap some photos and try to explain things a little. I'm taking mine apart to put a swivel snap on it.
step 1
Pick a side and undo the black strap, only on one side, feed it through the dee ring and all the small shiny ring that has the rope bridge attached.
step 2
Remove the clip from the strap, the one that would go around your leg, than pull the entire piece through the smaller black strap that is permanently on the ring.
Step 3
Feed the rope bridge end through itself, once your about half way down you can squeeze the ring through spliced eye of the bridge. Now to completely remove the bridge you don't have to take the other side apart, just feed the bridge through itself. Assemble in reverse, you can always look at the otherside to make sure your doing it right.
It took me 1/2 an hour with taking the pics to do all of it and put it back together. I didn't follow directions, this is just how I figured it should be done, or undone.
step 1
step 2
Step 3
