Stihl Kombi
  • Replies Replies 5
  • Views Views 2K
emr
Cheesehead Treehouser
Neenah, Wisconsin
Anyone have any experience with these?
http://www.stihldealer.net/category...toplvl-14-catid-14-subcat-14-catprods-99.aspx
My partner wants to get a cultivator for his garden and we were thinking about getting this Kombi thing and then we would have the power head for other applications. We would not use it daily, but maybe the versatility would be nice. We would consider getting the power sweeper, hedge trimmer, power pruner, and the cultivator.
I've got the Shindiawa version, power head, pole saw, cultivator, weedeater head and the ability to run a blade.
While I love the concept, for me it's been OK, as a pro, it's relying too much on one tool, if you can get that. Meaning, if I were a lawn pro, I'd have two weedeaters and at least one edger on the trailer, so I or my help isn't wasting time fidgeting around putting on the attachment needed!
If I were running a tree service, I'd have the extend a pole version of the pole saw, yeah they are a bit heavier, but so much nicer than the one length I am stuck with!
If I were Stephan, I'd have two dedicated brush cutters, with the wide handle bars and shoulder harnesses to make them easier to deal with for long run times.
What I'm trying to say, these fit a nice niche, but they really fall into the "Jack of all trades, master of none" category. Just something to think about.
I bought/ currently use the 130R (biggest) powerhead ($400), have an extension ($?) and power pruner (~$100, IIRC), brush cutter/ string trimmer combo, hedge trimmer with many angle options, and blower.
Agree with Andy on 'Jack of all trades, master of none."
Not pro-duty, but has treated me well. I do a very limited amount of power pruner work. Its been a help and functioned fine for some canopy raises along a boulevard in a housing area, cutting some dead branches from far away (lower down) in a hecka dying willow removal, occasionally dicing up a low limb rather than rigging it over landscaping, etc. The flip-cap leaks, most likely due to employee error in closing. Not too heavy, not too bad. Definitely made the money back that I've put into it.
The blower has been good overall, with good power. Used it the most. Did have to replace some parts in it, can't remember if it was some bearings or something. Still works well. Much, much better than the BG65 that I have.
String trimmer and brush cutter have gotten some serious work around my property and some other commercial jobs, but I'm by NO means talking the type of work that Stephen is getting out of his dedicated brush cutters. The little gray guide part that is on the end of the attachement where it inserts into the powerhead has stripped. Probably cheap to fix.
Hedge trimmer has been useful and good cutting. I have done a hedge of two with it, and used it to cut large sections of tall grass (reed canary grass 3-4') where the brush cutter would have more problems with it winding around the head and needing to be cleared.
No idea on the cultivator or sweeper.
Its been good overall. Again, not pro-duty. Not employee proof. Had it not been employee-operated, I'm sure it would have held up more.
Its been a good compromise. I have no need for a commercial string trimmer, brush cutter, or hedge trimmer. I'll hope to buy BR600 blowing power.
My engine has been cold-blooded, but always starts, just needing a little warm-up time for 1/2 a minute or so.
Depending on your needs, it could be a good homeowner tool, with some limited commercial application. Not letting employees operate it is best, but I've had them doing it for years, mostly with the blower and secondarily with the brush cutter/ string trimmer and pole saw
The little chest harness is cheap, and enough. A big help to relax the grip and avoid numbness from the vibration.
Agreeing with Andy again---->niche.
I have a 130R for personal use. Good posts so far, pretty much spot on.
I had the paddle type broom and didn't like it at all. Too heavy to be useful. My local dealer told me they hardly move any for that reason. If you're REALLY considering it ask your dealer to demo it at their shop. I bet you'll pass. Feedback on the bristle type was much better.
I have the cultivator and have been happy with it. Like others have said it's def not employee proof.
Power scythe is also well worth the cost.
