bstewert
I'm in the market for a saw around the size of the 362, and wonder pros and cons of the Quickstop feature. Or other comments on the saw, in general.
I had trouble finding the fast idle hot start position. Not real fond of the switch/choke set up. It rips.
Bt Stewart - did you program the auto-tune in as per instructions? They should start fine - did you prime it with the bulb or just as per normal?
Engine adjustment
The following steps should be taken when the chain saw
is started for the first time or when outside circumstances
change (fuel, altitude, air filter etc.): Start the engine.
Accelerate the engine to full throttle and saw a number of
cuts in a thick log (3-5 min.).
The chain saw must be run (8,000 - 12,000 rpm) the entire
time so that the carburettor can adjust itself
