MasterBlaster
Administrator Emeritus
It means don't throw the tree if you think it needs to be climbed to do it safely.
Another version is 'When in doubt, rope it out."
Got it! Thanks for the clarification, Butch.![]()
...endless variables dictate that no one philosophy or rule ever be cast in stone.
"we never move 'a certain way'....until we need to...and then we do.
Hey are those georgia boots? I was thinking of them myself...How do you like them? Nice echo.
Assuming one could get into work position here, do you guys ever make face cuts hanging off the low side and then swing back to the other side for the back cut?
Idk. My 590 is MM and tuned with a 3/4 wrap bars. It fairs well in urban logging imho.
Run away!!!!!!
Great pics!
...Tops that lean away can be hard to work with for sure. Sometimes you might try using another tree for your TIP and that can let you go places that are otherwise very hard to get to.
About the top...we can't see the full length of the top but judging from the spar you dropped there could have been a concern if the top was too long. If the top rotates over and the tip hits vertically or near-so, it can drive the butt where you just cut back into you while you are riding that bucking bronco.
If that scenario was not in your thoughts it needs to be...too big a top can hit the ground and strip you off the spar.
I thought the same as Gary. The butt can land backward of the stump if it over rotates and springs of the tip. A problem when there is an obstacle behind the stump.
Nice job of it.
Ask anyone here I'm all about the running away. Getting out of dodge once the cuttings done is always a good plan. Practice, practice, practice will make those cuts prettier.
I'm pretty sure that's uncommon on most trees most times, plenty of folks will make the face cut from "side on" though, its a handy position for that as you can watch the depth nicely. Nice work.
AND...too long of a limb when you are low in the tree can do the same thing...if you are at 15' above the deck and the limb is 20' long it better be a flat-drop cut...if the limb hinges down and the tip hits the ground first then the butt is coming back at you...capisce?
I have seen this ruin guys,will damage your body if that butt comes back n gets ya.
