combrig
Recently, I've been thinking of making whole new Speed Line Kit. I am really tired of improvising every time when it gets to Speed Line. But I have a few questions about the equipment needed and I will appreciate if you share your experience with this.
First - the length of the loops. I've decided to use 3 loops of 24 inches, 4 - 36 inches, 4 - 48 inches and 2 loops of 60 inches. I've never even thought of checking what is the length of the loops I use, so here I've just copied from WesSpur Speed Line Kit.
Do you have any other suggestions for loop length? Or maybe I have to exclude some of the sizes stated above?
Second - about the carabiners. I'm going to use oval shape, but the shape is the only thing, that I am certain about. I'm still wavering if the gate has to be with screw lock and what material should I choose.
The screw-lock carabiner can be used without screwing the sleeve every time, and it can be used for other applications if needed. If I choose non-locking oval carabiner, the only way to use it for other applications is opposite placement for 2 carabiners, and I don't really want to do that. I just don't like using climbing techniques. But it concerns me if the hatch of the screw sleeve can contact and damage the speed line rope somehow...
About the material - I am concerned, that the steel will move really faster than the alluminium and that it can be a problem. But the Alu crabs will wear faster... The weight of the steel ones can be a problem for some, but I think, that it's not a big deal... After all I don't have to carry the slings with me all the time. The ground will take care of sending them to me when they're needed...
I've decided to check my local equipment supplier, and it turned out, that the oval, screw-sleeve carabiner - Kong Oval Steel Classic (picture) is the cheapest option there is. The alu ones, even without screw sleeve, are 30% more expensive.
I will appreciate any other advice about the speed line equipment and speed lining at all!
