Old Monkey
- Joined
- Mar 9, 2005
- Messages
- 8,767
Silly Carl, you put it in reverse first.
You want to see a mini go sky high?
YesOne question. Was the top still in the tree?
If so I would try a sidehill cut next time.
Yes
Whats a 'sidehill cut'?
It's a local trick, though I believe the same technique is used all over the West. Basically, you make a very steep face that is about 90 degrees off the head, then your "backcut' or more correctly your "topcut" comes in at a very radical angle in line with the bottom of your face. Sounds crazy but it works like a charm. The tree pulls like it might barber but then swings into the face, and you will be amazed at the amount of movement you can get.
Leaves a high ugly stump, but removes the hazard of barber chair, and gets your tree into or much closer to lead. I learned it a few years ago when I had a strip of Alder and no amount of swing dutchmans, quarter cuts, or swizwills was keeping the damn things from either blowing up on me or rocketing down the slope, crossing my lay.
Diagram, or pic?
Whats a 'swizwill'?![]()
