Radiator Fin Comb
  • Thread starter Thread starter JohnB
  • Replies Replies 26
  • Views Views 3K
J
JohnB
I picked up a fin comb today and have never used one or seen one used. Any tips on using it so I don't do any more damage to the already bent fins
Never used one, I can only imagine what it might look like and how it would be used. I have straightened out more than a few radiator fins though. Automotive, air conditioners (central air units as well as window units) and other machinery. I think the last one I used a putty knife and a Stihl carb adjustment screwdriver.
Just be aware of how radiators work. The coolant travels through the tubes or jackets, the fins radiate the heat from the jackets via the air blown over them. So all you gotta do is open up the smooshed fins to allow air flow without tearing open the jackets. Patience is a virtue here, it's usually one fin at a time unless you have some fancy 'fin comb' type tool. ;) You will probably have to get the fins relatively straight before being able to use the comb anyway.
At a show I saw these tractor fans that would change direction every few minutes in order to flush out crud.
Seemed like a good idea for chippers which just stand there or tractors working in real dusty, weed filled areas
What you might want to do is invest in a battery powered lazer thermometer available at any auto parts store. Check to see what areas are building up heat. Chances are that the radiator is working fine if it is not boiling over so the combing would be for aesthetics.
If it is running too hot, flush, replace fluid, replace thermostat, check water pump, THEN comb those fins
Beware- New radiators are expensive !:cry:
They sure can be! Some guys hose out the radiator with water, I don't like to do this as wood swells. Compressed air done right does a good job.
Ya compressed air, I try to blow out my rads whenever I think of it. Tonnes of crap comes out of them.
  • #10
Those reversible fans can cost as much as $5000
A reverse fan won't really do much good .It just plugs up going the other direction .
Probabley the easiest thing to do is install a removable screen on the radiator . Periodically remove the screen and clean it out .
Yep. I worked with a guy whose wife would sew a cool cloth screen with stretchy attachments that would hook on four sides. It was easy to remove and shake clean.
My chipper gets a lot of stuff in the radiator. This is where a air compressor with the high pressure like 175 lbs or so comes in handy.
Steve, I've bent fins on a truck radiator using an air nozzle. It works great but if you get right up close and hit the fins at the wrong angle then they can bend over quite easily.
edit: Actually it was probably the air conditioner fins. Radiators are tougher.
Yup, sometimes got to give them a little distance. I always test it a little and you learn how close you can get. The fins on my chipper radiator are pretty tough. The fins on the air conditioning condensor on my pickup are extremely easy to bend over.
The fins on an air conditiong coil differ from those on a radiator .This is due to the extremely thin aluminun used in order to get max thermal transfer .
For what it's worth they are very easy to bend on regular refridgeration units also .On those,for those interested ,they make a type of soapy cleaner as a "coil wash " type of stuff .I do my air conditioning /heat pump twice a year .
Thinking out loud though ,now I wonder .It would be very easy to build a rack in the front of a radiator to actually use a furnace filter .Just toss em every couple of weeks .They only cost a buck or two anyway . It wouldn't get it all but should get the majority of stuff from clogging the radiator .
While on the subject they do make filter media that can be purchased in rolls ,relatively cheap too .We use this stuff at work to protect and filter the intakes of air conditioning units .
You have to use some discretion using a power washer .I have one that will strip morter joints on the narrow nozzle ,not the thing to use on a radiator of course .The wide angle one however will not harm the fins unless you get about two inchs away from them .
A pressure washer is almost the greatest invention since sliced bread or beer in a can but you have to use it properly .
While on the subject they do make filter media that can be purchased in rolls ,relatively cheap too .We use this stuff at work to protect and filter the intakes of air conditioning units .[/QUOTE]
I like this idea. I am also thinking that evaporative cooler pads would work well and breath well. Cheap too. They make them in that fiber material now. hmmmm :/:
filters block particulate material, but what really jams up a radiator is the ultra fine dust. Putting a filter in front usually leads to not cleaning the radiator regularly.
I prefer to be able to see my radiator, but I do have a mesh screen to block out the chunks
  • #25
When the reversible fan changes direction and blows into the engine compartment the engine block can freeze. So I read, maybe the kinks have been worked out since then.
