brendonv
Tree Hugger
I have a Stihl HT 131. I want to run the same chain as my 200t's for ease of making chains.
Am I correct to assume no matter what width the bar is, "3/8" Picco" uses the same size sprocket because the drive links aren't going to change.
I held up the factory chain to a 200t chain, and the distance between drive link is the same. I also just mounted my 14" bar with the chain from a 200t and it seemed to work perfectly.
I plan on just getting a 12" B+C for it, but wanted to test to make sure everything worked fine.
