Machining/welding/millwright…molten metal
  • Replies Replies 85
  • Views Views 6K
  • #54
Cattle feed mixer. Hundreds of tons of feed thru it per day. The feed goes into several semis that feed the cattle for about 8 hrs a day. They have 3, always a spare on hand. They last about 3 years before rebuild. Shell is broken and rusted out, gear teeth worn and loose on the shafts.
Fab a 💩 hole cover
Water clarifier leak to be repaired
Large hay baler flywheels getting new bearing carriers in the center.
Pump replacement job
  • #67
Quite rare we use that monster drill press any more
Modern CNC machines and their tooling are much faster…but that plate won’t fit
  • #74
Pretty heavy duty. Bad weld cause failure? Looks like it could use a bigger engine and pump for the size of the cylinder.
I think it needed a lower relief pressure for the size of the cylinder vs. the bracketry 😆
