sotc
Dormant hero!!
No doubt, I tried to order a toaster from him
Cody, check the electric fuel shut off valve in line from the tank to the pump. Pull it and blow it out. Had that happen with mine.. One little piece of fuel varnish or debris can get frustrating when it gets in there.
Yes it does. I dinked around with it a bunch today, and pretty much narrowed it down to a carb issue...I think?Cody, will it fire on either when it dies? That would rule out an ignition problem.
Going to take the carb off Monday to mess with it. My Neighbor suggested cleaning out the bowl on the carb, so that sounds like great advise. If it is beyond that, like a carb rebuild, I will probably have someone who knows what the hell they are doing, do it. Makes sense if it is the carb, as being a rental, I am sure that most of the folks who rented it filled it with crappy ethanol gas. Hopefully I can get it squared away so I can get to work with it.I think there is an electric fuel shut off on the bottom of the carb bowl. Might be a good idea to take it off and clean the bowl out. Fixed my mower when I had that problem.
Did you test the cut off switch on the fuel bowl while carb was out?
All things heavenly rarify to air. Trèès pŕoduce that heavenly air. Breathe air and take care.
