Tucker943
Bamboo Plantation Owner
That fella in the picture can leg press a thousand pounds. He is strong. He will get weak with the mini.
That fella in the picture can leg press a thousand pounds..
He looks alot like my last employee, good strong mutha but only down fall he had was he arm curled too many brewskys.That fella in the picture can leg press a thousand pounds. He is strong. He will get weak with the mini.
Um, no he can't. But he is strong, no doubt. What's with the shiny wheelbarrow?
That thing isn't doing you a bit of good on the job I'm on right now.... Removing oak trees from a raised deck. Everything gets rigged down. Once on the deck everything gets diced up and tossed over the edge to the ground below.
Sent from my SCH-I535 using Tapatalk
Its amazing how you can spin medium logs on a pivot point (chunk of wood under the Center of Gravity).
Hydraulic dump box hoist powered by the chippers hydraulics is a big labor saver
