Husky 540i XP
  • Thread starter Thread starter Djax
  • Replies Replies 9
  • Views Views 2K
Djax
Boston
Experimenting with the rear handle 540i XP. Has anyone found a benefit to running the bli300 battery over the 200x? My thoughts are stay with the 200x and have more on hand to swap out. Unless there is a significant difference.
Yeah my 540i's will pull 40 cm/16inches. The predecessor models would not. I switched to running mostly 14 inch bars because I use the 540i mostly for pruning, don't need 16" cutting length most of the time - AND - the 28" Stanly Fat Max plastic toolbox will perfectly hold two saws, charger and two spare batts.
Bucking cuts in bigger wood will take a battery down in about 10 minutes +/-.
