SouthSoundTree
Sounds like "catastrofying" the situation. All basic threaded plumbing parts, iirc.
Flying apart tools... CatastrofyingI just checked out that thread at treebuzz. Haven't been there in a long time, that place looks totally different. I don't care for the new look.
Interesting thread though. I've used both the Air Spade and the Air Knife. The Air Knife ran off of those 375 cfm compressors and it was like firing a 12 gauge shotgun. I would be interested in building a homemade one but like you say above, it's your ass if an employee gets hurt and not being an engineer, that's a good possibility with something homemade like that. Pieces flying off and unhooked hoses flying around wildly are not my idea of a good time.
Seen sunscald on maples but not bugs..yet.. Euc oil is a good repellent.That's deep. Pretty common unfortunately. Do you ever find that the newly exposed root flare, especially on thin barked trees, is now vulnerable to attacks by wood boring pests? I've seen this happen more often than not on Rcx projects where the flare was buried for a long time on maples.
Sure. I've used both Quik-jet and Arborjet systems. The Arborjet has been mainly Tree-age injections for emerald ash borer, and I've also used it to inject Lepitect ( acephate) for obscure scale in oaks. The Quik-jet has been miticides, insecticides and fungicides on various species. Both use the Stinger injector along with tree plugs which are inserted into the root flare( amount varies based on dbh). The plugs have a rubber stopper prevents liquid from entering or exiting the hole once fitted. You use the supplied bit to drill the holes about an inch or so, then tap the plug into place. Place the stinger IVs into the plugs, pump up the pressure and release the valve, and the liquid starts flowing into the tree. Uptake is usually fast but is dependent on species, condition, size, and the weather. The quick jet is the same but you simply pull the trigger on the gun to give it a calibrated dose per injection site.
Pros: less mess, no need to spray, no motorized equipment, no huge bulk of chemicals, no mixing of chemicals. Good way to get product into tree and treatment can last several years.
Cons : plugs are expensive at a dollar each. Can be unsightly on high profile trees and on smaller trees you are limited to how many injections you can do cleanly in its lifetime. Severly stressed trees are not good candidates for this as uptake may not be as good. There can be lots of little pieces it break or lose. Rubber gaskets an o rings blow out and parts kits are PRICEY.
