N
Newfie
Logs means you have a reasonably consistent COG of your load for a consistent tounge/axle weight ratio.
Loading debris makes the COG move around and goosenecks are more forgiving in that regard. As Justin mentioned, you can turn a good deal sharper. Backing is generally easier with a gooseneck, and bumps are smoother.
Still, if/when I get mine built, it'll be a bumper pull.
And in the end, if you are going gooseneck, then you really need a dedicated truck for it. In that case I'd just get a triaxle with a big loader and a dumping box.
