What Grendel said about initially tying your hitch so tight it kinks the rope slightly to the side is exactly what I do. Then bounce on your role and it stretches and sets enough to climb normally. IMO getting your hitch tight from the get go is really important.
My simplest fix for smoother tending was to add a simple bent gate biner to the bottom for an increased bend radius. This worked well when I was using 1/2" rope (xtc fire). Once I switched to Tachyon 11.7mm I found I no longer needed it, the system was tending so much more easily with the slightly smaller rope.
For some reason the drag and drop feature doesn't work when using my tablet, so I'll have to add the photos next time I'm on my laptop!
