PCTREE
I tried with a 6mm retrieval line. all I can say is Im glad I have a Wraptor!!
Now you must explain said trick to me.
I don't know why I was so reluctant to switch to SRT, just dogma methinks. But, forgive me as I have to ask to be splained stuff you Srt old hats know easily...
I'm either really thick or it seems that there is no difference to this from an RB that has a tail which extends to the ground, other than ease of setting the line from the ground (which is a big deal). The same amount of rope is utilised, no? Or are you clipping the smaller cordage to the butterfly or end of the spiked line?
My problem is conceiving of a way in which to work a tall tree SRT and also to retrieve the line once finished. I suppose one would likely always need to use a secondary line in order to retrieve an Srt system on a tall azzed tree.
Nick, when you base tie how do you advance your TIP/PSP? Do you yard all the rope up through a higher crotch?
Life is short, buddy. Don't spend all of it working.
