MasterBlaster
Administrator Emeritus
I always like to tickle a new chain to make it super sharp.
Jerry, Yes. I run mostly Carlton.-And you are correct it is usually very good right off the spool. It cuts a smidge better after a couple of touch ups but not enough for me to sharpen it before the first cut.
Well of course up the in there in the fringes of civilization it's likely the only one you can buy .Only chain I'll run.
Oregon can bite my arse.
Old farmer tale ,a sharp tool will make you money ,a dull one will cost you .
Stihl branded chain has it's claim to fame simply by the fact it is hard as a rock . It's not better chain just good chain that cuts longer between filings .
--and at twice the price it should last twice as long ,of which it does .So it's even Steven .
Now that said ,in no way am I down grading the Stihl chain .I have several loops and it's damned good stuff but pricey .
Oh just that it all cuts wood no matter who made it .So what are you trying to say?
----besides that I can set the oilers on some of my old gems to blow oil like old "Spindle top " if I so desire .There is one thing about this thread that has mystified me.
Some of you talk about dumping a worn chain and just putting on a new one fresh out of the box.
Does that mean you think a new unsharpened chain cuts well?
Last year or so Oregon let some loose with the side angle not cut quite deep enough on the round chisel .I run chisel, and if a guy looks at the factory grind, one will see the corners high, low and sometimes right on.
I used to use a Granberg electric sharpener on a jig when first getting into milling. I think that there are advantages when using a very long bar and wanting to keep the chain angles always consistent. If I was milling regularly now, I might be wanting to use it. I never had a problem with the stone loading up, either the ceramic or diamond type.
You didn't say whether he is using one with an angle jig or not. For regular chain saw use, I don't see much advantage over skilled free hand, by the time you set it up on the bar, you can have it 2/3 done with just a round file. Free hand, and having a proper
stationary chain grinder to use when needed, that's where I get the best results.
The chain saw rental place near me replaces the chain after every return, and gives them to me if I catch them before they get tossed. 3/8 -.058, wish they'd go to .050. I must have about fifty of those, all 68 drive links.
i could sharpen my saw up in the tree,if had to
