Reddog
I like a three strand home made ring and ring with steel rings. Easy peasy and works!
Same here.
I like a three strand home made ring and ring with steel rings. Easy peasy and works when I use it!
Jaime mentioned making his own conduit friction savers. The conduit is easy to find, but how would you terminate it? Just sawing it off is going to leave some jagged edges on the ends. Sherrill's have some sort of swaged ends on them it appears. Anyone know how they're finished off?
If there was an accident or fall that somehow placed enough force on that sling to break it, well let's just say I would most likely be screwed anyhow.
I think you need Jeff Jepson's Tree Climber’s Companion...LOTS of tips in that little book. It is where I learned how to set the FS from the ground, well illustrated and explained. I almost always set a FS before I go up, even on takedowns. If I am limbing on the way up I already have my 2nd safety set and sitting in the saddle is lots more comfy than leaning back on spurs.
http://wesspur.com/Books/tree-climbers-companion.html
to make the ends of the conduit rope friendly they use a threaded cap. i found a cap that is identical in the plumbing dept. at the hardware store. its part of a water tight conduit fitting, you have to take th fitting apart to get at it. if anyone is interested ill go find out the name and brand.
Nice book.
Here we are not used to set the FS from the ground. Personally I've never tried. Are there many advantages in it?
I think i will be messing up with the throwing line and lose too much time...
On big trees (even on removals) I'd rather set a semi-static rope, climb Srt on that , set my FS when I reach my TIP,and switch to Drt and start working on my climbing line.
I have a ring/ring cambium saver and an adjustable one. When you work on badly hacked trees (like most of the cedars or maples we have here ) where is difficult to find a strong TIP the adjustable is really useful. Even on small hacked trees where you don't have a strong TIP you can run your adjustable FS around some suckers and make a good tie -in ( think it is better explained in Gerry Beranek's fundamentals)....sure, they don't have to be twigs.![]()
