Drying eucalyptus
  • Replies Replies 167
  • Views Views 17K
Yeah maybe I’ll chainsaw mill that one instead of taking to the sawmill since it’s questionable.
I had 2”x8” heavy duty trailer decking in mind. The 1” seems good on our truck bed.
Jumbo sized. Do you never use splitting wedges, @davidwyby ? I'm not thinking I can recall you doing so, but that could be wrong, easily.
If I was to go after hand-splitting any of these nasties you show, I'd without a doubt be using multiple wedges.
What wedges do you use Burnham? I like the conical wedges for the first set, then use typical wedges breaking down the rest. Easier to get set, and sometimes you get lucky and get multiple splits, which I think is the design goal, but hardly ever works.
Nope. If I have to wedge, I saw. I like sawing.
That cut was actually a bummer. Looking at the outside of that chunk and all its brothers I figured they were cracked to trash/firewood. Apparently diameter slows drying and cracking. Maybe round tables then if I coat and store them inside to dry.
I only use the standard steel splitting wedges. Those cone shaped ones seem to me like they would be hard to get seated...but I have never tried one. I have 4, and on rare occasions have had all 4 in a single large round :). Like this.
I dislike sawing on rounds to reduce them. I have to do it from time to time, when large knots defy splitting into small enough pieces for the woodstove. But only when there is no other choice. Not sure why...maybe just because it disrupts my normal workflow as I make firewood :).
Wood Grenades work well in harder wood and soft wood soaks them up IIRC. Same with my Oz blocksplitter.
When I have to saw rounds, I know I’m going to. Big and or tough. I saw the log into rounds and roll the rounds alternating in opposite directions, then slice them up, but radially, not thru. Flop flat and chop em up. Cutting across the rings makes it easy, splits easy with the rings.
This one had been dead and drying on the stump a while, bark falling off. Still damp in the middle.
Overnight…but it doesn’t go deep.
Reminds me I need to paint some ends
Mesquite is way more stable
