BlackSmith
Uncivil
316 ss would be the real deal if available.
Stevo,
I'm climbing on a hybrid system composed of an srt line fitted with a DMM Pinto Rig Pulley. My drt line runs through the Pinto Rig pulley. (This pulley is clearly marked for CLIMBING USE ONLY).
This hybrid system addresses and cures two problems in one simple package. The first issue was safety and rescue. I wanted a system that my helpers could use to get me down out of a tree in an emergency, with little or no training. The Srt line and base tie addresses this issue. The second problem was with isolating my climbing line and removing the unwanted branches from between the two lines of the drt system. Hoisting the drt system into the tree with the srt line was an instant cure to the isolation problem.
I still climb on the drt system using a the DMM hitch climber pulley and a prusik, but I'm now using a DMM Pinto Rig pulley as my top anchor point. Super smooth. Extremely fast to set up. No more isolating the two drt climbing lines. No more worries about emergency rescue.
Should I ever need to be rescued from the tree, my ground workers can now undo the carabiner securing the Timber Hitch at the base of the tree and then use the friction of the two wraps of the srt climbing line around the tree to safely lower me to the ground.
Hope this helps.
Joel
When you guys order from Tree stuff do you phone orders in or use the web page? Just wondered if discount worked for phone orders. I've never ordered from Tree stuff before mainly because wesspur is close to my location and I can phone in orders (which I prefer) but the 10% off might be a game changer.
